C
CHRISDOW
First post here, I have a budget of around £1200 to buy a 32 inch LCD,
Having bought various magazines, it seems the new Toshiba 32WL48 is the best at present. I am just put off with it being a "Toshiba" as in my eyes, prob wrongly, I never classed them as well as Sony or Panasonic, even Sharp.
It is important that it is HD compatible also.
It seems the new Toshiba has everything I need, and is on the net for a shade over £1200 delivered, great I thought, as i would much prefer the 32 inch over a 30 inch.
Now coming from a man with a Bush 28" widescreen at present, not even flat screen!! I know I will be impressed, there is just a little doubt in my mind at the moment regarding the "quality" of Toshibas.
Am I completely wrong in thinking this?
I prob dont have the greatest dvd, vcr and surround sound system, Sony and Philips, but the screen, being the most expensive component in my system, needs to be good so I can upgrade as money allows.
Any advice or other screens I should look at, been reading WHAT HI FI mainly, are these in any way biased towards or against certain brands.
Cheers in advance
Chris
Cheers in advance
Chris
