32" Hd Ready Lcd
Discussion in 'LCD & LED LCD TVs Forum' started by s1hastie, Aug 3, 2006.
Tags:
  1. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    Im in the market for a new tv. Looking for something around 32" lcd HD Ready.
    Needs to be wall mountable and I must be able to connect my laptop etc up to it using the vga cable. Built in freeview tuner would also be a good bonus.
    Anyone got any reccomendations for something decent that will last either if you own it already or know someone that does or have heard good things,
    Only drawback is I only have around £500 to spend!
  2. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    subscribing.
  3. satvia geez3r
    satvia geez3r
    For that sorta money your gonna have to go for one of the lesser brands or perhaps one of the older 'branded' models.
    Im quite new to the LCD game, but i've heard some good things about the Acers and Loewe models.. they may come in at around your budget but as the ol saying goes.. you get what you pay for. Depending on your viewing distance/room size etc.. you may be better off getting a 26".. £500 = 32" average display/no name/possible reliabilty issues.. or £500 = 26" tried and tested brand, better display.
    You could be unlucky and pay for a branded TV and get dead pixels or it goes bang after a few weeks but i'd say it's less likely. I've just brought myself the Samsung LE27T51B (£500) but it's for my bedroom so 32" really wasn't needed. This models been out for some time, hear pretty good things about it, good value for a branded TV, im not bothered about HDMI.. it's got HDCP-DVI and it plays well on xbox360 (the only thing im using it for)..
    Don't forget.. what you using the TV for? Terrestrial TV? HD? gaming? different screens tend to be better for different materials (I hear panasonic (DX50/500) are reeeally good for standard analouge signal)..
    Sorry not much help, but if you provide a bit more info im sure this place will come up with a few suggestions.
  4. s1hastie
    s1hastie
    Apr 10, 2005
    2,505
    68
    +39
    mmm mabye should consider a 26" this is for the bedroom as well. But living at home at the moment so was thinking 32" so its something of a half decent size to take with me when I move out.
    Will be using it for tv viewing, not skyhd at the moment but will want to eventually. Will also use for gaming and hooking laptop up to for internet surfing.
  5. Downinja
    Downinja
    Mar 11, 2005
    2,103
    116
    Chesterfield
    +632
    Q321 - £600 ish
    Has built in tuner, 1:1 Pixel mapping for great looking connection to PC, lots of connections for future proofing, great spec, 32", wall mountable.
  6. satvia geez3r
    satvia geez3r
    this is the one i've heard many good things about.. 32" okay its £600 (but you won't find much cheaper with this quality).
  7. juniper
    juniper
    Dec 30, 2003
    1,903
    48
    +60
    Seconded - I have one too. Stonking TV, HD ready, 8ms response, detachable speakers, doesn't have too big a footprint, and the PQ puts my old Panny 32" CRT to shame. Excellent purchase:thumbsup: .
  8. bcham
    bcham
    Feb 11, 2005
    908
    bradford
    +50
    i have the 6th one down http://www.aria.co.uk/productslist.asp?Submit=search&Category=253
    perfect picture ;good for dvds and xbox360 and pc.for the price you cant go wrong,
  9. samjpullen
    samjpullen
    Nov 24, 2004
    3,882
    Keighley, West Yorks
    +142
  10. bcham
    bcham
    Feb 11, 2005
    908
    bradford
    +50
    i can play hd threw the conponent cable.on sky hd box.or xbox360 hd add on.when it arrives.
  11. Entertainment
    Entertainment
    Jun 13, 2006
    237
    Newcastle, UK
    +9
    In "What HDTV" SKY Said they would allow "older" HD TV's to use the cononment to connect the SKY HD Box to the TV. How ever they did saythat it would only apply to SKY's channels, other channels (third party) can choose to block it for copy protection.
    Thanks,
    Andrew.
