32" for PC
Discussion in 'What Is The Best TV For You?' started by ninhydrin, Aug 26, 2013.
  1. ninhydrin
    ninhydrin
    Nov 28, 2007
    329
    +7
    I'm after a 32" LCD or LED to go in the bedroom so nothing too fancy but I'm also wanting to use it as a PC monitor too.
    Would a budget of £300 get me anything decent?
  2. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    Thread moved
    Curly
  3. VEGACORTEZ
    VEGACORTEZ
    Aug 6, 2006
    509
    43
    +212
    Samung 32" F5000 as reviewed on * is under your budget and would suit your needs, you just need to rename an input to pc when using one to make sure you will achieve rgb 4:4:4 like a pc monitor for a crisp picture, you can use the cinema preset for other usages. If you fancy paying a bit more then the sony W6 32" one is a great tv and it is more a mid range one with great upscaling etc but you may not need all these things for more casual use.
    Regards
