32" do i need DVI for PC ?
thedude2011
Established Member
hi guys need help picking a 32 inch TV.
I am looking to buy a 32" tv with a budget of around £550
Here is what i will be using the set for,
PS3 Games /blueray Movies
Xbox360
PC Screen does this need to be DVI ?
SD TV and Freeview if built In needs to be a good SD picture.
Thanks Regards Anthony.
Panasonic TX32LZD80 32'' LCD for 530 from electrical-deals.co.uk looks good any recommendations and advice is appricaiated.
Ben
Assuming the video output on your PC is DVI, you can connect it to the TV using a DVI to HDMI lead/adapter. You'll just need to run a seperate cable for audio.
If the video output on your PC is VGA, you can connect it to the TVs VGA input - again, you'll just need to run a seperate cable for audio :)
Nielo TM
It would seem that panny is the only choice.
But before you buy it, make sure it has 1:1 pixel mapping (which I'm sure it does, but its best to double check it).
PS: Try to get it from a well known dealer. JL is selling it for £600, but try to price match it with RicherSounds.
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
