32/37/42pf9986 Philips uses Sharp LCD Panels
Discussion in 'Philips TVs Forum' started by jdl, May 26, 2004.
Tags:
  1. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    :lesson: The new LCD's from Philips uses Sharp's LCD panels, I discovered that when i entered the service menu.
  2. idhutt
    idhutt
    Would you mind posting the sort of options available from the service menu? Im not really clued about these menu's so don't really know what they contain. Im specifically looking to see if you can tweak the inputs - ie change RGB to component on one of the SCARTs.
    Ian
  3. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    :lesson: There are no options to change the nature of the inputs, but you can alter a lot of other vital things for the picture quality.
    A dramatic difference is when you change the LUMA GAIN from 1 (default) to 3 this affects the overall brightness of the panel but it can age the panel faster.
  4. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Actually, that's not completely correct. Only the 32 LCD uses a sharp VA-panel. The 37 and 42 use a LG.Philips S-IPS panel.
    Furthermore there is no option to select YPbPr on the scart inputs. However, I heard from a reliable source that there is a firmware update expected in the coming weeks which would enable component (480p/576p/1080i/720p) on the DVI input. :thumbsup:
  5. JH4
    JH4
    May 6, 2003
    2,402
    63
    +245
    How do you enter the service menu ?
  6. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    062596 then [i+] ;)
  7. idhutt
    idhutt
    That is, I think, fantastic news :clap: and probably sold me on the Phillips, providing PQ is good. Can someone keep us posted about this update, and BTW, how would one apply the update or would I have to buy it with it? Im assuming that the DVI input, when used digitally, handles HDCP? What about DVI at native resolution?
    -Ian
  8. mine
    mine
    Feb 8, 2004
    128
    19
    88512 Mengen Germany
    @50 Hz ?????
  9. paul3_uk
    paul3_uk
    Apr 13, 2002
    45
    North Yorkshire
    Does anyone know if the 37" is going to be available in the UK .... 32" is too small and the 42" is too expensive.
    I have heard conflicting reports on whether the 37" is going to appear on the UK market.
  10. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    720p standards are supported at 50 and 60 Hz, the same goes for 1080i. Also 1152i is supported. I'll try to find out about the 37 in UK. It's bound to come into the shops in the coming weeks.
  11. alasdair
    alasdair
    May 14, 2004
    77
    glasgow
    +16
    Taking delivery of mine tomorrow and was a bit disappointed it didn't accept component as an input, but went ahead anyway as the opinions here are very positive.
    If there is a firmware update would I be able to update mine - and how would it be done ?
  12. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Any set can be updated, but I don't think it is that easy. You would need an I²C interface and a byteblaster. I don't recommend trying anything like this yourself. It would have to be done in a service centre unfortunately.
  13. mine
    mine
    Feb 8, 2004
    128
    19
    Good news indeed - 720p@50 Hz
    Do you listen Panasonic ?? after selling us 3 Generations of very expensive Plasmas without PAL resolution and NTSC refreshrates
    :devil:
  14. hornydragon
    hornydragon
    Dec 19, 2001
    28,310
    +1,217
    Hmmm seems a number of manufacturers are using 30" Sharp panel!!!
    ASV is very good why not consider LC-37HV4E orAD1E from sharp???
  15. jrecampbell
    jrecampbell
    May 14, 2004
    56
    A relative newbie question, but how would an analogue component output from my Panny DVD player input into a digital DVI connector? Are there adaptors you can buy?
    A related question would be: can you get splitters that allow multiple component-capable devices to use one component input on a screen?
    Still this is great news as I was considering this unit but the lack of component input was a problem.
  16. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    This Philips has a DVI-I input that means it can accept both digital and analog signals, right now the situation is a little bit cloudy and no one can confirm if this input can accept progressive signals, the only test that i did is connected the DVI-D output from the Samsung HD-935 and the panel accepted all the resolutions from 576p to 1080i but the picture quality was really bad. :oops:
    I really dont know what is the problem but i don't think that is only the DVD player.
    We will keep you posted for updates in this matter.
    As for the 37 model the Philips here in Athens told me that it will hit the stores around September.
  17. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    I almost forgot when you feed this panel with a digital signal the Pixel plus 2 is turning off :mad:
    Hope this is not happening when you feed the panel with a progressive scan signal using the analog route of the DVI-I input.
  18. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Be aware that when setting the input source to 'digital set-top box' the TV puts the smart picture mode automatically to 'soft'. For bad digital transmissions, this is not a bad thing to do, but for good quality stuff, set the input type to anything else and you can set your picture preferences yourself and the TV will remember it.
    For availability of the 37 in UK: yes it will be sold there and it will arrive in the shops by the end of June, not september.
    For the DVI stuff: I checked both analogue and digital signals and the following are supported:
    DVI: 480p, 576p, 1080i50, 1080i60, 1152i, 720p50, 720p60, VGA 60, SVGA 60, XGA 60.
    Analogue RGBHV: 480p, 576p, 1080i50, 1080i60, 1152i, 720p50, 720p60, VGA 60, SVGA 60, XGA 60.
    The supported YPbPr formats as already mentioned earlier will be similar, except for the PC formats of course.
    The way you have to connect the YPbPr to the DVI is like this: The TV comes with a DVI to VGA adapter. Use this and together wit a VGA to cinch cable and you're all set (or to BNC which is easier to find together with 3 bnc to cinch adapters).
  19. paul3_uk
    paul3_uk
    Apr 13, 2002
    45
    North Yorkshire
    LiquidB, this is good news. May I ask what source you heard this from?
    Two of us from this forum have had two different responses from Philips regarding this matter (beginning of July (me), not at all (other person)).
    You'd think that Philips would know when and where their products are going to be launched.
  20. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Well, It is understandable that there is some confusion. Originally, it was planned to launch the 37 after the holidays, but some weeks ago, this was changed to let's say beginning of July. This actually means the first products will be shipped in about two weeks and arrive some time later in the shops.
    It would be only normal in a big organization that not everybody is aware of this change.
  21. paul3_uk
    paul3_uk
    Apr 13, 2002
    45
    North Yorkshire
    LiquidB,
    Very true, but it gets a little frustrating to us consumers when you are trying to make a decision involving thousands of pounds and you get confilicting reports from the company making said tv's. Do you wait even longer and hope the TV comes out at the size and price that you want, or just take the plunge and re-mortgage the house.
    Thanks for your reply.
  22. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    Hi I tried last night what you told me ( I found a VGA cable with 5 BNCs in the other end, I plunged the DVI adapter to the VGA side and 3 RCAs adapters to the RGB BNCs ) but there was no picture at all. :mad:
    The VGA for the Philips does it need to have a special pin order or can I use an ordinary computer VGA cable to 5 BNCs?
    Please help what i want to do is connect my progressive scan output from my Pioneer DVD668 (3 RCAs) to the DVI-I input of the TV, is this possible can the panel accept progressive scan signals?
    Thanks in advance.
  23. LiquidB
    LiquidB
    May 25, 2004
    93
    +19
    Well, I wrote there was going to be an update for YPbPr support, which would actually mean it is not supported today. So don't bother trying, it won't work untill you got the good software. I will come back on this once it is available
  24. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    Thanks a lot please keep me posted, and one other thing do you know if the new 37 supports this option? :thumbsup:
