32" 1920x1080 available from Sharp
Discussion in 'LCD & LED LCD TVs Forum' started by gjm928, Jan 2, 2007.
Tags:
  1. gjm928
    gjm928
    Dec 29, 2006
    71
    Does anyone know anything about these? Apparently Sharp are manufacturing the LC-32GS10 and LC-32GS20, the difference being the position of the speakers. They're quoted as being full HD, which if the XD1E range is anything to go by, means 1080p.
    2000:1 contrast ratio, 460cd/m2, 176 degree viewing angle.
    Should have been released in Japan just before Christmas.
    I'm sure there's a discussion in here somewhere about the merits of a 1920x1080 resolution 32" screen...
  2. B-real
    B-real
    Oct 26, 2006
    96
    +14
  3. tornadotsunami
    tornadotsunami
    looks great but is it hdmi 1.3? it seems pointless to go for a 1080p display without it with the technology pretty much out there and everything..
  4. gjm928
    gjm928
    Dec 29, 2006
    71
    That's the one. The same info is on trustedreviews, with a pic of the set with side-mounted speakers.
    There was me all set to persuade my wife that we really needed a 37" set - probably the LC-37XD1E - and then Sharp go and do this. If I'm honest, I may be being a tart about the whole 1920x1080 thing and we probably don't need anything larger than a 32" screen. Then again... :rolleyes:
    Would SD look better from a distance on a physically smaller, true-HD set (when compared to a 37" or larger screen)..? Or would we not be able to tell?
    Price is rumoured to be approx US$2400.
  5. Hi-Def
    Hi-Def
    May 17, 2006
    1,220
    48
    Coventry
    +42
    NICE
    just gotta hope for the holy grail lol
    1920x1080p through VGA, component and HDMI and all 1:1 pixal mapping
    but maybe asing for way too much
  6. gjm928
    gjm928
    Dec 29, 2006
    71
    All is likely to be revealed at CES 2007 on January 7, 2007, 12:00 PM - 1:00 PM, when Sharp will be holding a press conference.
    Might be a bit in short supply for a while - Sharp estimate manufacturing 5000 GS10s and 4000 GS20s a month to start with.
    I've picked this up from Sharp's press release. I don't know enough (either Japanese or technical stuff about panels) to give a good technical translation, but hopefully you'll get the idea.
    Picture size: side 69.8cm×length 39.3cm/diagonal 80.1cm)
    Horizontal 1,920× vertical 1,080 pixels
    Brightness: 450cd/m2
    Contrast: 2000: 1 (living contrast 900:1)
    Video: VGA, 525i (480i), 525p (480p), 1125i (1080i), 750p (720p), 1125p (1080p)
    Viewing angle:
    Top and bottom 176 degree
    Left and right 176 degrees
    Speakers: 6.5cm×4 and 2.0cm×2
    1-bit built in amplifier 20.0 W (10.0 W + 10.0 W)
    Power: AC 100 V 50/60Hz
    Power consumption: 166 W
    Standby power consumption: 0.08 W
    Annual power consumption: 155kWh/year
    Dimensions (without speakers):
    Width 81.5cm× depth 11.8cm× height 52.0cm
    Dimensions (with speakers):
    LC-32GS10: Width 81.5cm× depth 11.8cm× height 60.2cm
    LC-32GS20: Width 99.1cm× depth 11.8cm× height 52.0cm
    Dimensions on stand:
    LC-32GS10: Width 81.5cm× depth 30.4cm× height 66.3cm
    LC-32GS20: Width 99.1cm× depth 30.4cm× height 58.9cm
    Weight (without speakers): Approximately 17.0kg
    Weight (with speakers):
    LC-32GS10: Approximately 19.5kg
    LC-32GS20: Approximately 20.0kg
    Tuner:
    VHF 1 - 12ch and UHF 13 - 62ch
    CATV 13 - 63ch
    BS digital 000 - 999ch
    110 degrees CS digital 000 - 999ch
    Ground digital 000 - 999ch (CATV pass through correspondence)
    Connections:
    Video input 4 systematic 4 terminal and S 2 image input 2 systematic two-pole :confused:
    D 4 image input 2 systematic two-pole and HDMI input 2 systematic two-pole :confused: :confused: So there's 2 HDMI ports!
    DVI - I input terminal
    Monitor output 1 systematic 1 terminal (S two-pole attachment and video input 4 video recording output terminal combined use) :confused:
    Headphone output terminal
    digital voice response (light) 1 systematic 1 terminal :confused:
    Center speaker input terminal and speaker connected terminal (input?? :confused: )
    I.LINK (TS) S400 two-pole
    B - CAS card slot,
    Terrestrial analog digital antenna input terminal
    BS 110 degree CS antenna input terminal
    Telephone line terminal and LAN terminal (10BASE-T/100BASE-TX)
    Video controller terminal and AC input terminal
  7. tornadotsunami
    tornadotsunami
    Damn that is NICE! Price? Got my arm and leg ready :D
  8. Dr_Mike
    Dr_Mike
    Mar 10, 2004
    379
    Loughborough
    +16
    Has anyone heard any rumour of UK release date for this ? I've seen a thread on avs suggesting it'll be out in the US before the end of this month.
    I'd be very interested in this set as it could offer the "holy grail" of 1:1 mapping from PC at 50Hz in a 32" set.
    From
    http://babelfish.altavista.com/babe...atch.impress.co.jp/av/docs/20061213/sharp.htm
