31LG5700 set up with PS3
Fitzp
Hi there
I just gone bought a 80GB PS3 to go with my 32LG5700, I have connected the PS3 using HDMI cable, can anyone recommend the best settings on both LG and PS3 for blu ray play back.
Monarch
Nobody can really say, set the PS3 to output at 1080p, just put everything on automatic for the quick option. You might find that PS3 games (in 720p) will be outputted at 720p and not 1080p, in which case untick 720p and 1080i as supported resolutions on the PS3's display settings. Make sure 1080p/24p (or something like that) is set to automatic, that way it should send everything how it should be, that setting is found on the video/BD settings list. On the TV you just need to make picture adjustments, if you can then calibrate it, otherwise you might want to get some settings off the forums somewhere, but be sure to tweak them to your preference and viewing conditions
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
