300w micro atx psu
Discussion in 'Computer Components' started by cowtipper, Sep 12, 2004.
  1. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    Hi guys
    I need some help i bought a compucase 7328 recently.
    http://www.xcase.co.uk/acatalog/Compucase_7328_Micro_Atx_Desktop.html
    it came with a 200w psu which i thought would be enough to run my system and it is for everything except my ati 9600 256mb card with this card installed it just wont power up i know it is the psu as i have plugged in a 400w atx psu and it works fine.
    i thought the psu was noisy anyway and planned on either replacing the fan for a vantec stealth fan or purchasing a new psu
    so heres my problem i cannot find any 300w psu's available seperatley
    i can find them installed in a case but not on there own.
    and i cannot really change the case as it is the only case i could find slim enough height wise to fit my av rack.
    unless someone can recommend a case that will fit 44cm deep x 44cm wide x 14.5 cm high.
    so has anyone got any web sites or ideas to help me out :lease:
  2. HMHB
    HMHB
    Nov 11, 2001
    27,188
    Nottinghamshire
    +6,125
    It might be worth asking the people at kustompcs if their 250W Micro ATX PSU would be any good ?
    Kustompcs
  3. cowtipper
    cowtipper
    Jan 29, 2004
    165
    19
    Thanks for that but it needs to be at least 270watts as i will be using approx 261w fully loaded i think i may have to ditch my case which is a shame as it is a really nice case and it fits in my av rack
    and i have scratched it so i wont be able to sell it either :suicide:
  4. wyerd
    wyerd
    Dec 29, 2000
    761
    28
    Upstate New York. USA
    +27
