n3ur0
Established Member
I am thinking of upgrading my 1005's to either the 3005 or the 5005. Since they are both priced around the same if you had the choice which set would you go for? I'm just curious.
Also I have a denon 1906, do you think it will be beefy enough to cope which such speakers or would I need to invest in a newer model?
Thanks!
Thanks!
