I've done a quick search but probably not thorough enough. Apologies if this has already been discussed at length.
Considering the pros/cons of a 30" computer monitor vs. a similarly spec'd LCD TV.
I'm looking to buy either to use exclusively as a computer monitor. I don't want it as a TV or for watching blu ray or for playing games consoles.
I want to use it with my Mac Pro and also a custom built gaming computer.
1080p is certainly a minimum, the obvious advantage of Dell/Apple 30" displays is that their resolution is 1600p. Aside from that, monitors are often more than double the price of a 1080p LCD TV.
My question is whether there are any problems I will face using an LCD TV as a computer display, I've noticed on some admittedly older plasmas (720p) that the image looks fairly awful.
Any advice?
Any advice?
