30" Aquos wall mounting bracket
Discussion in 'Home Cinema Buying & Building' started by niallsmart, Jul 2, 2003.
  1. niallsmart
    niallsmart
    Mar 27, 2003
    24
    Does anyone know what type of wall mounting bracket is required for the Aquos LC30HV4E?
    Regards,
    Niall
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Unicoll do one IIRC
  3. niallsmart
    niallsmart
    Mar 27, 2003
    24
    Yeah... C&M do one for £99 which seems like pretty good value if it swivels up and down. I thought that was expensive but I can't see it cheaper anywhere else....
  4. Gordie Glasgow
    Gordie Glasgow
    I agree i've found UNICOL are the best for all size of brackets (LCD & Plasma). They will even try their best to 'custom' make a bracket for you if you have any specific non-standard requirements.
    www.unicol.com
    Hope this helps.
