3 x male component to 15-pin VGA male?
Discussion in 'Cables & Switches' started by mg23, Mar 28, 2006.
  1. mg23
    mg23
    Mar 26, 2006
    To connect my Freeview box (with RGB Scart output) to my projector (with Component input via 15-pin D-sub) I'll be using a converter box like the QVC QED. I've been having trouble finding a cable which would connect from the converter to the projector though.
    It would need to run from the output of something like this:
    [​IMG]
    to input number 14 in this image:
    [​IMG]
    So basically I need a 3x component male to 15-pin d-sub male cable, if it exists. I've found a few similar ones on ebay in America but they all seem to be advertised as vga to component cables, the wrong way round. Anyone know where to get hold of the cable I need? I'm fed up of watching Freeview via composite video.
    Many thanks
    Mark
  2. pjclark1
    pjclark1
    Jul 19, 2004
    4,463
    Thailand
    +271
  3. 12 promises
    12 promises
    Aug 18, 2004
    1,555
    2
    dunfermline
    +119
    try mark grant.
    high quality and next day delivery,a bit more expensive than e-bay though.
  4. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    I'll throw CPC into the pot as an off the shelf cheap solution :)
