Question 3 Subs?
Discussion in 'Subwoofers' started by pws, Jan 11, 2019.
  1. pws
    pws
    Jan 27, 2004
    2,169
    Swansea
    +191
    Hi All,
    I have two subs in the front corners.....I also have another sub (All diy and the same) lying around...as you do.
    Has anyone ever in 3 subs with the 3rd behind the listening position?
    Paul
  2. paulst10
    paulst10
    Dec 16, 2004
    12,437
    Essex
    +1,844
    Hi, very briefly yes, although they were far from identical (two SB13Ultras up front and an Arendal Sub3 behind my sofa) Firstly I'd like to point out that this was just for fun and I didn't really have any intention of keeping it that way. Anyways, It didn't really work out due to Audyssey detecting the very different roll offs and messing up the low end but if it weren't for that I reckon it could have been made to work. I can't see you having any of those issues with 3 identical subs and a MiniDSP.. You haven't still got those huge towers have you?
  3. pws
    pws
    Jan 27, 2004
    2,169
    Swansea
    +191
    I'm just thinking what to do with it really lol
    Huge Towers??
  4. SonOfSJ
    SonOfSJ
    Jul 8, 2012
    2,216
    116
    Edinburgh
    +1,074
    I have three identical Tannoy TS12 subwoofers in my bedroom, one underneath each of the 90cm-tall front left and right speakers, and the third underneath the one of the row of chairs immediately behind my bed. I do mainly listen to the surround-sound system when I'm actually in bed, so yes, the third subwoofer is slightly behind me then. The third subwoofer, although I've had it for years, was added to the bedroom in only about October last year, and I do notice the improvement.
  5. paulst10
    paulst10
    Dec 16, 2004
    12,437
    Essex
    +1,844
    Yeh, give it a try if it's just sitting there :smashin:
    Didn't you have those two huge black cylinders once?
  6. pws
    pws
    Jan 27, 2004
    2,169
    Swansea
    +191
    ah....no....i wish i did...i think it was swiftpete.....monsters weren't they :)
  7. D1gita1
    D1gita1
    Thursday
    29
    3
    7
    Ls18
    +14
    Chances are it won't work well. That's not to say it cant, but careful set up is required if you dont want to negatively impact the overall sound. Gain matching and time aligning the subs will be very important. The other thing of note is that adding a second subs to a first gains 6db of extra system power, while adding a third sub to two only reaps half those gains overall. If you have it lying around there's no harm in trying, but I'd advise you do a bit of studying up on the finer details of settings subs up if you haven't already to ensure you get it right.
