3 sata drives and only 2 sata connections!
Discussion in 'Desktop & Laptop Computers Forum' started by Cameron, Jul 2, 2004.
  1. Cameron
    Cameron
    hi there, my motherboard has 2 sata connections (as well as 2 sata raid 0/1 connections that I'm not using).
    I have just bought myself another sata hard drive so that makes 3 drives and 2 connetions. Do I have to buy some type of add-on pci card so that i can run my sata cable from that to my hd?
    If so, does anyone have suggestions for a cheap sata pci card?
    Is there away of making my 2 spare raid sata connections into plain old sata connections? my motherboard is an asus
    4800 ai one from memory.
    thanks
    CaM
  2. owain_thomas
    owain_thomas
    Sep 29, 2002
    1,953
    Manchester, England
    +84
    not sure about your MB, but if you need a cheap sata pci card, maplin do one for £20-30, works fine.
  3. Cameron
    Cameron
    ok, thanks for that - I'll check that out asap.
    CaM
