3 lights of death help
Discussion in 'Xbox Forums' started by Toffeeman, Feb 3, 2009.
  1. Toffeeman
    Toffeeman
    Mar 3, 2005
    232
    +3
    Hi, my Xbox seems to be dead :(
    A simple restart is no longer doing the trick and it refuses to live.
    Problem is, upon registering my Xbox I have found it to be out of their 3 year warranty(?). I'm confused as I bought this brand new from Boots in January 2007, so it should be well within the 3 year period?
    I've also struggled to speak to a person at Microsoft regarding this, so I was wondering if anybody can advise me about this 3 year warranty thing and also if there is a number for help.
    Thanks in advance.
  2. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    there are numerous posts on the web and also one on here somewhere that details a posiible fix for your problem if it is out of warranty just search 360 rrod. for help
  3. astar0th
    astar0th
    Mar 12, 2008
    6,205
    Mojave Wasteland: Holding Kav's hand
    +1,243
    Check the back of the machine and post the manufacture date.
    If your saying it's older than 3 years i'm guessing you bought a 2005 model in 2007?
    Boots old stock?
    If the manufacture date is after February 2006 then it's definitely covered.
  4. shagaboopon
    shagaboopon
    Nov 22, 2006
    3,279
    North Yorkshire
    +367
    If Microsoft really aren't interested then you can always approach Boots regarding getting them to replace the product under the SOGA. There is a thread on here with an example letter you can fill out to get them to replace it for free. Its not always simple getting it done but if you pesevere and know your rights then you should be fine. To do this method then you really need the original receipt or some form of proof of purchase.
  5. Munkey Boy
    Munkey Boy
    Nov 23, 2003
    16,960
    2
    2
    Manchester
    +4,473
    The warranty they refer to on Xbox.com is the standard 1 year warranty for all faults, you will definitely still be covered for the 3 years for the RRoD fault despite this message. If you do go back to your retailer (like I'm doing), then there's help in the FAQ at the top of the forum.
  6. Toffeeman
    Toffeeman
    Mar 3, 2005
    232
    +3
    Thanks, that's a quality thread!
  7. knight2000uk
    knight2000uk
    Dec 16, 2008
    825
    28
    +77
    Most likely the GPU thats shorted solder or a bad solder ball, what does your error code come out at?
    Turn it on let it RROD, press the little circular sync button and hold it, then press eject 4 times, upon each of those 4 presses you will get a number of lights
    4 lights = 0
    1 light = 1
    2 lights = 2
    3 lights = 3
    Post up the code and if you cant go through boots to get a refund there are other ways of fixing those 3 lights.
    Stu
  8. SteveU30
    SteveU30
    Oct 2, 2008
    5,537
    +1,985
    The 3 year thing is just a goodwill gesture from Microsoft.
    The Sale of Goods act is much more powerful as it covers you for up to 6 years after purchase (5 years in Scotland) for an inherent fault (which RRoD is as MS have admitted it).
    As mentioned already though, you would need proof of purchase (a bank statement is sufficient) and you would have to go through the retailer not MS as your contract is with Boots.
    Hope this helps!!
  9. Toffeeman
    Toffeeman
    Mar 3, 2005
    232
    +3
    Although it states out of warranty on the website, having spoken to them the other day they immediately accepted I was within the 3 years and are sending UPS to pick it up for a free repair/replacement :thumbsup:
