Hi all I have just cleaned 2 projectors a sanyo plc se10 and a toshiba tlp s10d
I had to seperate the lcds from the prism to get behind to clean the dust, which was pretty bad on these two.
The lcd's have 4 countersunk screws on both projectors and each has 3 lcds RGB ect...
After I put these back and screwed them in when switched on the image on the wall has this problem where the 3 images are seperate by about 10 cm red image to the left and blue to the right.
These where all in perfect sync before I cleaned so can anyone help me with what I need to do to get them back in line. ?
am I right in saying it is the lcds that need to be adjusted and not a lens that I might have moved ?
I cant see where any adjustment could be made as I would presume that the countersunk screws would line the lcd up to perfect position.
Any advise would be greatly recieved.
