3 diff outputs to 1 Svhs input
Discussion in 'Projectors, Screens & Video Processors' started by cutes6, Mar 4, 2001.
  1. cutes6
    cutes6
    Jan 3, 2001
    795
    Near Leeds
    +26
    Help please !!! I have a normal vcr with standard Scart output and Sat box with Rgb output and a Dvd with Svhs output.Is it possible to buy a box of tricks that will take these 3 different in puts and produce a single Svhs output for my projector.It would be nice if this box exists if I could control the switching with a Pronto.What would a 7 to 10 mtr length of good quality Svhs cable cost and what cable would you recomend for the same length of normal composite cable
    Thanks in advance
    A sucker for Toys !!
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,552
    Newcastle
    +337
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,572
    Somewhere in South Yorkshire
    +6,092
    Cables: I use a 10m S-video cable to run from my players/amp to my projector. It as "Prowire by Vinvanco" cable, bought ex stock from a Sony centre in Leeds for £35. It's fine.
    Another good source for cables is Lektropacks.
    As for switching sources - I use my Home Cinema aplifier for this purpose - all equipment outputs routed into the Amp - the amp video output is routed to my TV and projector; audio goes to the speakers (surprise).
    If you really need a separate switching box - again, Lektropacks have a range.
  4. Jagular
    Jagular
  5. cutes6
    cutes6
    Jan 3, 2001
    795
    Near Leeds
    +26
    Thanks for your replies guys I am very gratefull.I live near Leeds so I will give those guys a ring about the cable.Will the quality of the svhs output differ from a normal scart input as opposed to a rgb/scart input? Perhaps if I list my equipment somebody might advise me of the best setup just incase I am missing something here.
    Projector with 1 @ composite and 1 @ svhs input
    Sky sat box with 2 @ normal scart and 1 @ composite output
    Pioneer 636 dvd with 1 @ svhs and 2 @ scart output(1 is rgb but no rgb link through ?)
    Sony vhs with 2 @ scart and 1 @ composite output
    Sony strdb 925 amp with separate buses for composite and svhs inputs/outputs.
    Are there leads which I can buy that have scart at one end and svhs at the other and then I can use the amp to do the switching assuming it does this on the svhs bus system
    Sorry for going on and I am probably just confusing myself even more and I need to be put straight, Thanks
  6. cutes6
    cutes6
    Jan 3, 2001
    795
    Near Leeds
    +26
    Yes its me again there was one more thing what is the best coaxial cable to use for about a 25mtr run to the projector to recieve channel 3 as Sky havnt got there finger out yet,thanks
  7. lmccauley
    lmccauley
    Oct 24, 2000
    3,552
    Newcastle
    +337
    I think your best bet would be to do as Nigel has done and route everything through your amp and connect its s-video and composite outputs to the corresponding inputs of the projector.
    You have two options with your digibox:
    1) Connect the lower quality composite output to the amp or;
    2) Use a RGB to s-video converter (£60-80) to connect to your amp.
    Personally, I would choose option 2 as there is a significant difference between composite and s-video.
    Cheers,
    Liam
    "Do you hear that, Mr. Anderson? That is the sound of inevitability."
