3 channel power amp?
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by ajwoodhouse, Oct 21, 2004.
  1. ajwoodhouse
    ajwoodhouse
    Currently using Denon DVD-2200, Sony STR-DB780 receiver and Yamaha 5.1 sub/sat speaker package for multichannel duties and a Naim hifi for stereo.
    I now want to use the Naim amplification (and spkrs) for front L/R (it has unity gain for AV) along with a Rotel processor I've just bought (used RSP-976, not interested in prologic II or any more than 5.1).
    I was thinking I'd stick with the sony for now and use the analogue 5.1 inputs to input preouts from the rotel for centre and rear surrounds and I guess this would work but would be clunky.
    Can anyone recommend a cheap 3 channel power amp to go with this? Pref s/h and not more than £300 if poss :blush:
    I listen to music more than movies/multichannel music so don't want to spend a fortune! Front speakers are B&W CDM1NTs and speaker upgrade may come later.
    Many thanks
    - Andrew
  2. cameronl
    cameronl
    Aug 13, 2002
    1,217
    38
    +11
    there was a second hand arcam P35/3 for about 400ish a couple of weeks back. I'd look for an ex-dem / second hand P35/3 or for that matter any arcam poweramp that will accept an extra power channel.
    CaM
  3. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    A bit over your spec but what about a Rotel RB 985 Mk II? It would be over your budget but then again you probably would be hanging on to it for a while !
    Let me know if you are interested and I will make an enquiry to see if it is still available.
    regards
    Parmenion
  4. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    £300 for a 985 MK II isan't that over the top.
    I was offered two within the last 3 months for £300 on here and another forum. It would be idea for what you want.
    Try and get hold of one secondhand you will not be disappointed.
    Steff
  5. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    Nice to see you back.
    regards
    Parmenion
  6. roydonaldson
    roydonaldson
    Apr 15, 2003
    304
    19
    Glasgow
    +3
    Andrew,
    I've gone through this path myself. Have you considered picking up a second hand Naim 90 x 2 or Naim 140 x 2 to run those other speakers off.
    I've gone from using a single NAP140 + Yamaha DSP800 to running 3 x NAP 140. It's been worthwhile taking the time to pick up the other boxes second hand and staying with Naim for amplification. I got one of the 140's for £250 from my dealer.
    Roy.
  7. ajwoodhouse
    ajwoodhouse
    To clarify - I'm looking for a fairly cheap power amp that I can use to power my centre and rear surround speakers.
    Naim would be nice but TBH even s/h is too expensive for the amount it gets used :eek:
    A rotel probably makes more sense given it will be paired with an RSP976 processor.
  8. Parmenion
    Parmenion
    Feb 6, 2002
    1,258
    Out there
    +50
    Please see my post above !
    regards
    Parmenion
  9. avanzato
    avanzato
    Jan 21, 2003
    1,963
    Norfolk
    +82
    Why not get two of the Rotel stereo amps, about £100 each S/H or one of their 6 channel jobs and bridge it £200-£250 S/H.
  10. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Would something like this do the trick? Run it bridged and you get 3 channels at 90W each, or you could have all 6 channels driven at 30 Watts which opens up the possibilities of bi-amping :smashin:
    Check out the manual and power specs here
    Can you guess what I have lying around unused? ;)
    Regards
  11. Alphatoner
    Alphatoner
    Sep 28, 2004
    713
    28
    Berkhamsted
    +40
    I've got a Yamaha DSP E800 which i used very effectively with an Arcam Alpha 10 before i changed to a full AV setup.
    Well within your budget.
    Ian
