3.5mm switchbox
Discussion in 'Cables & Switches' started by GuitarGuy, Jan 7, 2012.
  1. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    ive got a new headset and to use it right, im gonna be using optical for the audio, i need to hook up the mic to both the mix amp and my pc soundcard and wanna be able to switch between the two without unplugging, is this possible? I also need one for optical audio. do such boxes exist?
  2. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    Anyone?
  3. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
    I think a bit more on what kit you have and what connections they have would help out with any advice to be offered!
  4. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    Of course! Ok so I have my ps3 and my pc, I want to connect my senheister pc 360 headset into both of them. I've got an astro mixamp 5.8 (the wireless one). This does audio via optical. For the mic to the ps3 it has an USB lead specifically for it, for the pc I wanted to plug the mic directly into the mic in port. What I'm asking is, is there a device I can plug both optical cables into and have one lead to the mix amp which I can switch with a button, and is there something identical for the mic so I can plug one directly into the computer and the other into the mix amp to go to the ps3 (again with a switch).
  5. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
    Ah, OK. I *think* I get it.
    By the sounds of it you need a simple optical switch that allows you to select either the PS3 Optical out or PC's Optical Out and for that to be fed to your astro amp.
    Something like this:-?
    "Expensive type" - 2 Way TosLink Digital Optical Audio Switch | Audio | Switches | Audio / Video | LINDY UK
    "Cheap type" - http://www.amazon.co.uk/TOSlink-Optical-Switch-3-Port/dp/B001NXK9DG
    As far as the mic side goes, would this do?
    3.5MM STEREO JACK FEMALE TO 2 x 3.5 MALE PLUGS 1.8M | eBay
  6. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    That's perfect for the optical! Thanks! As for the mic, not quite, I wanted something basically identical to the expensive toss link box but for 3.5mm audio jacks. I don't want dual output from one source, if that's easier to understand. Also I assume not because its digital but is there any difference in quality between the two optical ones you linked?
    Edit: effectively like you said I wanted a switch to direct the output of the mic to either the pc OR the astro mix amp.
  7. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
    Either of the optical switches will work. Whether the cheaper one will last more than 6 months of use is another matter!
    As for the audio, the link is not a male to two females (i.e. split an output), its a female amd two males (i.s. split an input). You stick your mic into the female bit and the two males will give you the two outputs.
    It's a 3.5mm STEREO Socket to 2 x 3.5mm STEREO Jack Plugs.
    [​IMG]
  8. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
  9. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    I got what you meant with the first one but I wanted it either to one or the other but not both at the same time. But the second one you linked seems perfect! Thanks a whole bunch! :)
  10. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
    If you didn't want to spend $25 on the switch, there are instructions on the net how to make your own. Simple, but fiddly if you're not used to soldering.
  11. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    im an electronics student, soldering is no problem for me, its just a case of quality?
  12. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,815
    2
    The Fylde Coast
    +13,357
  13. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    Seems like more time than it's worth, I'll just buy one, but thanks :) that's all I needed.
