3.5mm jack to RCA
Discussion in 'Home Cinema Building DIY' started by CodeThief, Nov 11, 2003.
  1. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    Anyone made one??
    I havent ordered one and don't want to pay £4 for shipping for something that costs 99p :D
    Which bit is which??
    Does the shaft of the plug attach to the outer ring on the RCA and the tip to the centre pin??
    Dave
  2. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    No-one know??? :(
    Dave
  3. pc99
    pc99
    Feb 28, 2001
    255
    Milton Keynes, United Kingdom
    +3
    Yes, the tip of the 3.5 mm plug goes to the centre pin of the RCA(Phono) connnector and the shaft to the outer ring.
    If it's a stereo 3.5mm plug then the tip goes to one centre pin, the ring to the other centre pin and the shaft to both outer rings.
    If you don't want to make one and you have a local Maplin store they sell an adaptor for 99p and you won't have to pay postage.
    (Product Code is RW04E).
    They also do ready made leads.
    Regards
  4. CodeThief
    CodeThief
    May 25, 2002
    660
    UK
    +5
    Top banana, thanks for the reply :)
    I don't have a local Maplin or I'd have bought one :( :( :(
    Oh well, I'll have a nice shiny silver and heatshrunk adapter instead :D
    Dave
  5. Goof
    Goof
    Oct 14, 2002
    771
    Scotland
    +3
    I was in the same position when needing an adapter a few weeks ago in that I didn't fancy...erm...bending over and paying that amount of postage on :laugh:
    Luckily The Ritz helped me out :clap:
