30th November
This is for a church PA system that's probably about 20 years old and still works.
I want to send audio output from a PC (3.5mm headphhone output) to an XLR socket that is about 4m away, which then runs back to a mixer.
Where should the conversion be done and what cable to use to give a good (not perfect) solution? So for example which is better,
a 3.5mm to XLR adapter local to the PC and then a long balanced XLR cable or
a 3.5mm to XLR cable that's 4m long or ?
I read about things like TRS, Neutrik but these don't mean a lot to me. Any recommendations of cable suppliers also welcome.
Many thanks
30th November
Many thanks
30th November
