TekWarfare
TL;DR:
I'm looking for a compact, but full-sounding 3.1/5.1 setup for my small room that is 2.2 x 2.4 m (5.3m²)I want a centre channel, but not bothered about surrounds/sides
The max depth of the satellites is 9cm but I can give some leeway
The max measurement in a single dimension of the sub is 25cm
I don't want to spend more than £150
I would like to use them for Movies and TV; gaming and music are secondary
Current considerations:
Cambridge Audio Minx S215 (or equivalent)
Canton Movie 75
Mission M-Cube+SE
Kef Kube-1 & HTS1001.2 [satellites are nice and compact but sub is 5cm too big]
Need a compact but capable AV receiver with two optical inputs (TV and PC). That's it.
Basic DTS and Dolby Digital decoding would be nice, but I've converted my whole library to AAC
Any help and advice is greatly appreciated
Details:
Fronts61 x 27 x 9 cm (HxWxD)
I want to wall-mount the front-left and front-right so ideally they'd be no deeper than the TV (~9cm at the mid-point)
The TV is 61cm in height and there's 27cm clearance on either side of the TV
Centre
Below TV: XX x 27 x 8 cm (HxWxD)
Above TV: XX x 106 x 10 cm (HxWxD)
A PC monitor is just below the TV so if I mount the centre channel underneath the TV the max width is 27cm and the max depth is ~8cm
If I mount the centre channel above then ~10cm depth is the limiting factor and 106cm is the width of the TV
Subwoofer
25 x YY x ZZ cm (HxWxD)
The subwoofer will be going under my bed and the clearance in height is 25cm, but I could add stumps to the bed legs increasing the height by a centimetre or two
I have my current upright sub lying sideways so the woofer is firing into the floor; I'm happy doing the same with another sub so 25cm is the max in any one dimension
My current setup is Logitech X-530 5.1 and I'm fairly happy with it performance for movies, TV, gaming, and music. I also like that I can EQ it with software. Unfortunately, it only has those typical PC speaker connections - Green Orange Black cables (6ch direct) - so I can't get true 5.1 out of the TV.
