2xRGB sources, 1xRGB Input - suggestions?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by evildonut, Jun 13, 2003.
  1. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    I've got a Nokia Mediamaster 221T Frreview box, and a DVD player. Both are RGB-capable.
    Unfotunately, my TV only has 1 RGB Scart input!
    I tried routing the DVD player through the Nokia box, but its Aux Scart doesn't seem to pass through RGB.
    My DVD player only has one scart - bummer!
    So, is there a 'scart doubler' I can get that would allow me to use RGB for both boxes without degrading the sound at the same time?
    PS - Getting a new tv is unfortunately not an option at this stage :(
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    Dixons group sell a JVC 4 way scart for £15.99 I have one as i am in the same boat so to speak. I dont think it degrades quality at all (use good scarts Obviously) Its is passive and auto switching (only one device on at once) I'll have a look for the link for you mate.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  4. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    Thanks dude, I'll look it up in a minute :smashin:
    Just a thought - I usually leave the FreeView box always on. Does this mean that if I want to watch a DVD I'll have to switch off the box?
  5. Kevo
    Kevo
    Aug 23, 2001
    5,395
    Manchester
    +147
    QUINTRO+
  6. SOUNDSTYLE
    SOUNDSTYLE
    Oct 4, 2002
    1,271
    +52
    Try 534/0370 at Argos.
    I had exactly the same problem as you and purchased this scart switching box.
    I can't detect any difference in sound or picture, and it only cost £9.75!
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    I tried an argos one first but it wouldn't pass RGB!!!
    one the freeveiw you need to but the box into stanby to watch a DVD not off at the mains. It does mean you dont have to get off your arse to press the little button though (like on some Argos ones).
  8. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    hornydude,
    Thanks for that! I think the quintro+ is a bit OTT for my needs :blush:
    Now, off to Dixons I say!
  9. cbemoore
    cbemoore
    May 16, 2002
    1,225
    38
    Esher
    +16
    Argos sell two switches. The one with the cable attached will NOT pass RGB, so its a bit useless.
    But the other one (with no cable attached) will pass RGB.
    Chris
  10. Fernsehman
    Fernsehman
    If you just want a scart switch, satcure.com do a cheap manual one that's RGB compatible on all inputs. 2-way or 4-way.
    Fman
  11. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    Dear lads,
    Scart switcher from Index (or Littlewoods). It costs about £6 and can handle RGB, S-VHS and composite. 3 inputs with 1 output )to the TV) - all rgb enable.
    There are buttons to allow "pass-through" for recording and L+R input sound.
    Got one msyself! The only down side is that it is manual operated to switch input e.g. from PS2, to sky-D.
    :p
  12. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Hi wading in at the last minute here, I have precisely this setup upstairs, and my Nokia 221t passes RGB thro without a glitch. Check further before wasting money & time. Faulty lead? DVD decided not to output RGB after power off? You can leave the nokia on, just as well as it's only fault is that off command, the dvd will just overrride it when turned on. The reverse is true, though, you can't watch TV with the DVD turned on.
  13. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    Hi MAW,
    Well I've tried that, but it doesn't seem to work. When the Nokia box is on, and it goes to the proper AV channel, my TV shows "AV1/RGB".
    However, when I switch on the DVD player (through the Nokia box) the TV shows "AV1" :(
    If the DVD player is plugged straight in then I get "AV1/RGB" as well.
    Que???? :confused:
    Maybe I should try again, but what could have gone wrong?
  14. cbemoore
    cbemoore
    May 16, 2002
    1,225
    38
    Esher
    +16
    If the Nokia box is switched on, it will output its own picture, not the DVD player's picture. RGB passthrough will only be enabled if the Nokia is switched off (or in standby).
    In general, if you are daisy-chaining devices via scart, you need to switch off all devices that are closer to the TV than the one you want to view.
    Chris
  15. joshua_bond
    joshua_bond
    Jun 25, 2002
    342
    +16
    Cbemoore it correct.....a way forward is to plug your RGB sources direct into the the scart switcher - with the output to the TV RGB input.
    It does not matter if all your sources are on. The switcher from Index discrimates (depending on the input selector on the switcher).
    The downside is that the switcher is manually operated.
    Hope that helps.
  16. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    Hey MAW,
    Well I've tried again last night
    DVD >(aux)> Nokia >(tv)> TV
    But to no avail! I've tried with the Nokia on, off, no difference! The Nokia displays as RGB no prob, but the DVD comes out as composite from both RF output and Scart.
    Aaaaaaaaaaaaaaaaaah!!:confused:
    I think I need to drop a line to Nokia again :rolleyes:
  17. bobones
    bobones
    Jan 15, 2002
    453
    +7
    I tried again too, and my 221T most definitely doesn't pass RGB, either on or off.
    Maybe there are different versions? Mine says hardware revision 5, firmware 1.1.2 in the Systems settings page.
  18. evildonut
    evildonut
    Jan 21, 2002
    91
    9
    Ecosse
    I've just had a look at the tech specs, and the 'Aux' socket is not wired for RGB - I can't see how it could pass through RGB then!
