2x2 Component video splitter
Discussion in 'Cables & Switches' started by edent, Apr 24, 2007.
  1. edent
    edent
    Mar 30, 2005
    345
    Oxford
    +18
    I have 2 component sources (Xbox and Wii). I have two display devices, a projector and a TV - both have 1 component input each.
    I want to passively split both signals and then recombine them. I won't have both signals on at once, nor will I have both display devices on at once.
    I could build on using a bunch of bits like this http://www.kenable.co.uk/product_info.php/products_id/404
    But I'd rather use something like http://www.cyberselect.co.uk/product/1028
    So, is there anything which will go 2 to 2?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,720
    The Borders
    +3,513
    Hello terryeden
    Not many 'passive' 2x2 devices on the market.
    Have a look at the JS Technology 2x1 switch + 1x2 Splitter - saves any potential problems with having more than one Source active plus you can view the selected image on both Displays simultaneously; see http://www.js-technology.com/
    Joe
  3. the_Geezer
    the_Geezer
    Aug 12, 2004
    470
    +26
    You can get a 4x2 one from KEENE
    Which I think are very good products
    The AVT5842MX is a 4 input by 2 output switcher that can be used for either YPbPr Progressive Scan Video or YCbCr Component Video, plus Stereo Audio. It is a dual output switcher and sends the selected input to the outputs independently. Since it is a Matrix Switcher, each of the two outputs can have the same or a different video signal, selected from the four inputs. Selection can be made by the front panel push buttons or by the IR Remote Control.
    Specifications
    4 Component Video Inputs via RCA connectors
    4 Stereo Audio Inputs via RCA connectors
    2 Individually Selected Component Video Outputs via RCA connectors
    2 Individually Selected Stereo Audio Outputs via RCA connectors
    Works with Progressive Scan YPbPr 480p, 576p, 720p or 1080i Component Video
    Works with Interlaced Scan YCbCr Component Video
    IR Remote or Manual Control
    Video Bandwidth: 100MHz
    Channel Separation: >50dB
    Noise Reduction: >50dB
    NTSC and PAL compatible
    Size: 1.9" High x 9" Wide x 5.7" Deep (48 x 230 x 145mm)
    Weight: 2 lbs (920g)
    12VDC @ 185mA Power Consumption
    220/240VAC Power Adapter Included
    http://www.keene.co.uk/electronics/multi.php?mycode=AVT5842MX
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,720
    The Borders
    +3,513
    Hello the_Geezer
    Note the AVT5842MX is not rated for 1080p - not an issue for some but will be for others if they suffer image degradation through the switch.
    Joe
