2x monitor out?
Discussion in 'AV Receivers & Amplifiers' started by woody183, Aug 16, 2002.
  1. woody183
    woody183
    Please help me.I have recently purchased an Onkyo 595 of which i am very pleased with.I have everything connected to it via S Vid which then connects to my tv/projector via S Vid on the monitor out.My problem however is this.....I KEEP HAVING TO CHANGING THE S VID PLUG ON THE BACK EITHER FOR THE PROJECTOR OR THE TV!!!!!!.mad:mad: mad: Is there a device that i can split the s vid monitor out into two? As you can imagine it is a nightmare dragging my av unit in and out.....
    any help would be great:
  2. paiger
    paiger
    Here's a long shot. If you don't have your VCR on the VCR1 svideo output, can you use that as a second monitor out? Or, if you do, can you not run the signal through your VCR in some way using a scart to svideo cable?
    Otherwise, not sure. You can probably get an svideo splitter box. Try Maplin or Lectropaks
    Steve
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    VCR out is always a good bet.
