Now that they have dropped the subscription, for another £200 and £10 mirror subscription you can have another sky+. Whack in a 120gig hard drive and you get 60 hours more time (my sky+ is always full), and another two feeds.
A good point wilber!!!Sky+ for another room but not the same!!!!! I could almost understand a 2nd box in the same room but why not get a second HD and swap them! or even get a panny DMR 100 or a DMR 50 and just use ram discs if you reallly want 2 in one room then the only way to do this would be manually block the IR reception of the one you didn't wnat to control there is another way but that requires a new TV LMK if you want details.
Attach one to each Sky+ and secure the IR receiver into different corners.
Cover up the IR control on both Sky+'s.
You may need to build an open box around the IR links to block stray IR codes but this should allow you to point the remote control into a corner and only control 1 Sky+.
