2nd projectors
Discussion in 'Projectors, Screens & Video Processors' started by jasoncp, Dec 19, 2002.
  1. jasoncp
    jasoncp
    Dec 12, 2002
    889
    28
    +52
    do i go for a cheaper 2nd hand unit as it is my first step?
    ive found a few an necvt 540, sanyo plc sw 15 , sanyo plc xw15 , sano plv 30 fo around £750 to £1000
    or should i cough up some more dosh and go for a panasonic ae100/200 or a z1?
    how would the 4 2nd hand ones compare to the pan and sanyo?
    cheers for any help
  2. GaryG
    GaryG
    Nov 20, 2002
    754
    Shropshire
    You've probably read it several times before but you really will have to have a look at the picture on the units for yourself. What is acceptable to one person may not be acceptable to somebody else, they all have strengths and weaknesses. As a general comment second-hand can get you a real bargain as projectors drop in value very quickly just watch out for bulbs near the end of their life they are an expensive item to replace. Also check out a plain 'white field' picture and look for signs of aging (yellowing), some projectors have internal filters that 'yellow' with the UV light from the bulb.
    If you can accomodate the size, a CRT will give you a better price/performance ratio and potentially last longer as tubes usually last around 10,000 hours or more although you will need to check the tubes to make sure there aren't any burns from overdriving the tubes (too bright a picture) or displaying static images like the logos on the Sky channels.
