2nd m.2 slot on asus x570 pro
Wagz
2nd m.2 slot in asus pro x570 pro
Hi, I have a decent build with a 3070, 5600x on an asus prime x570 pro. For boot drive, have an 1TB inland for os and such and has worked fine, gen pcie 3.0. It's full, so I'm looking to add a 2nd m.2 to the 2nd m.2 slot on the board. This will work of chipset and use some of the lanes. As far as I know it will not affect anything with the 1st m.2 using the 16 lanes. I have called asus to try to figure out exactly what's compatible. I guess any nvme m.2 with work, not said about sata. This willl be for game storage. I know the 2nd m.2 is signifigantly slower working off chipset. I have looked at all reviews between 3.0 and 4.0 and it generally seems not worth it to gain .5 to 1 second. All connections are gen 4 pcie. Didn't bother worth 4.0 on main drive. Wondering if because 2nd m.2 drive is already slowed down from being on chipset, and gen 4 pcie might actually make a difference. Prices are getting pretty close gen 4 vs 3. like 20-30 dollars maybe at most compared to ss 970 evo plus. Course Asus recomended using 4.0, were vague about wha m.2nvme is compatiablie. but not sure if it will actually give faster speeds on 2nd m.2 slot which has heat sink. Will gen 4 help already slow speed of chipset 2nd m.2? going to go 2 TB. Any recomendations would be great. 2nd m.2 info is not great in user manual or anywhere. When i do crucial checker, they always assume i'm using main m.2 cpu slot. Thanks.
EndlessWaves
The M.2 connector only supports four PCI-E lanes, not sixteen.
While both AHCI and NVMe PCI-E drives were available, the former died out pretty quickly so you can assume any new motherboard which claims PCI-E support on the M.2 connector will support NVMe as it's the much more popular protocol for PCI-E drives now.
If it's for game storage then I wouldn't agonise over speeds as games aren't very demanding of disk performance. It might make a couple of seconds difference on loading screens but other than that any moderately fast drive is going to be identical.
