2nd hand graphics card- good deal?
Discussion in 'Desktop & Laptop Computers Forum' started by WSB, May 19, 2005.
  1. WSB
    WSB
    Dec 31, 2004
    354
    +7
    I currently have the GeForce 4200Ti 128meg card but saw this on my intranet- good card/deal?
    256MB Radeon 9600 8xAGP Graphics Card with Dual DVI
    Excalibur Radeon 9600 graphics card. Bought 6-8 months ago for intended upgrade, but when I upgraded it was to a PCI-E card, hence this card.
    Specs are:
    9600 Radeon VPU
    Dual integrated 10-bit per channel 400MHz DACs
    256MB DDR SDRAM
    AGP 8x/4x
    15 pin VGA adaptor for analog
    S-Video connector and cable
    2 x DVI-I connector for digital CRT or flatscreen
    Independent resolutions and refresh rates for any two connected displays
    Windows XP/2000/ME/98/98SE
    In box with driver CD and original games CD.
    £30
  2. DaveP
    DaveP
    Seems good value for a 256Mb. I'd buy it!
    Dave
  3. Skunkpipe
    Skunkpipe
    yup that's about 1/2 price. does it have a fan or is it passive?
  4. WSB
    WSB
    Dec 31, 2004
    354
    +7
    too late- it went(!)
    my geforce fan is making alot of noise compared to the rest of my box- do you know a good quiet graphics card for use with MCE? Not really a pc gamer as i have the xbox so its just for general media stuff- video, recording, etc
  5. Skunkpipe
    Skunkpipe
    plenty - question is how much do you want to spend?
  6. WSB
    WSB
    Dec 31, 2004
    354
    +7
    I dunno- give me a budget option and then a quality option and I'll take my pick from there. I dont want a graphics card over 200 squid thats for sure- I quite like the idea of the cards with no fans though.
    Needs to run a 1366 resolution for my 32" lcd screen via dvi.
  7. Skunkpipe
    Skunkpipe
    Radeon 9200 (all of these are passive)~ £30
    Radeon 9600 Passive ones available for ~£70
    Sapphire Radeon 9600XT Ultimate (Passive) ~£90+
    Geforce 6600GT Passive ~£150
    The latter 2 have heatsinks both sides of the board so you might need to check they'll fit in your case (they won't fit in a Silverstone LC11 for instance)
  8. WSB
    WSB
    Dec 31, 2004
    354
    +7
    Thanks for that- you've been pretty much spot on whith your opinioins on kit so far- took your advice and got the fanmate 2 with an ultra quiet fan - works a charm- well- when i stop the fan on the gfx card from spinning :D
    You are wise and yet you are not on the jedi council :nono: (guess who went to see star wars last night)
    would you go for a 256mb 9200 or a 128mb 9600?
  9. Skunkpipe
    Skunkpipe
    no need for 256MB - esp not in a 9200 to be fair - MCE doesn't need that much and any game requiring that amount will struggle on a 9200
  10. WSB
    WSB
    Dec 31, 2004
    354
    +7
    i went for the 256mb 9600 in the end. If I'm upgrading my kit i might as well do it properly.
    thanks for all the help.
  11. Skunkpipe
    Skunkpipe
  12. WSB
    WSB
    Dec 31, 2004
    354
    +7
    thats exactly what i went for....
    and exactly where i bought it from too :rotfl:
