2nd box, 1 feed, no subs.
Kev12
Hi.
I've got HD with the full package.
If I were to acquire a second HD box and I connected it with only 1 sat feed, and didn't pay the 2 extra subs, ie £9.75 X 2 for multiroom and HD, what channels would I receive( HD), and what functionality recording wise would I get from the extra box?
wellfan
You would receive the 'free to view', or should I correct myself and say 'free to air' channels, and no recording facility.
Kev12
Ok, thanks for that.
By free to air channels, I'm assuming you mean BBC HD, C4 HD, and a couple more, which I can't re-call. If I paid Sky the HD sub, what would that get me?
I'm thinking it would be a "mirror" of my main package, is that right?
Only, only being able to view whats currently on the main box, if they were both on at the same time?
Hope I'm making sense!
Kimberson
on another note if i brought a new sky hd box off ebay for instance and put it in the bedroom. Would i be able to use the sky+ feature without paying for multiroom.
Matt
bladedripper
Matt
No.
Broadz
You won't get Channel 4 HD if you don't put a card in the box - it's FTV, not FTA.
You can't take out just a HD sub on the second box, you need at least one mix, but far better (and cheaper) would be take out multiroom - and possibly a second HD sub.
If you take out multiroom - you'll get all the channels on your main package except the subscription high def channels. You'll have to pay for a second HD Pack if you want an exact mirror of your main box.
No idea what your comment about only being able to view what's on the main box if both switched on at the same time means. The two cards/boxes are independent of each other. Neither gives a monkey's what the other box is/isn't doing.
