2mb Memory Stick problem
Discussion in 'PS Vita Forum' started by sirp, Oct 21, 2005.
Tags:
  1. sirp
    sirp
    Jan 20, 2002
    905
    28
    Derby
    +59
    has anyone else bought one of these yet? if so, please see my problem and let me know your thoughts, cheers
    bought a 2gb sony pro duo for my psp, pop the little fella in my 'sandisk' adaptor, pop that in a card reader..try to transfer data and it fails after several seconds with CRC errors or wrong parameter errors!
    pop it in the psp, connect psp to pc, data transfers fine....hmmmm!
    tried the card reader on another pc, same issue.
    tried a different card reader, and different sandisk adaptor, same issue.
    so i returned this, and got another..guess what..same problems!!
    what is going on, anyone know?
    surely it cant be the sandisk caddiesnot working with them?
  2. smallmanongn
    smallmanongn
    Have you tried NOT putting it in a card reader but connecting the PSP to the comp directly?
    It does say you shouldn't format the stick on your PC as the PSP might not recognise it,maybe putting it in a card reader has a similar effect in that the card reader cant read it properly.
    Just a thought!
  3. sirp
    sirp
    Jan 20, 2002
    905
    28
    Derby
    +59
    yes, see above, i stated that it works fine in psp then direct to pc
  4. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    Hi Sirp,
    I have a 2gb Sony card and it seems to work fine in the card reader built in to my Epson RX420 printer using the memory stick adapter. I do have a problem with both the 1Gb and 2Gb Sony cards in two different usb card readers though. Couldn't say why, but must be some compatibility issues somehow. The 32Mb card that came with the PSP works fine in the two usb adapters.
    Cheers,
    Pete.
  5. sirp
    sirp
    Jan 20, 2002
    905
    28
    Derby
    +59
    cheers zoidy, its not me going mad then! my 32mb one works fine too in my readers!
    its crap eh!! im tempted to return it again and get a sandisk on
