2k to spend on Plasma Help needed urgent
Discussion in 'Plasma TVs Forum' started by philp_i, Mar 14, 2006.
  1. philp_i
    philp_i
    Aug 1, 2005
    92
    Hi, Im after spending 2k on a new plasma, im not to upto date on which model would suit me best.
    I have Sky+, and xbox 360 and im thinking about buying a dvd player with HDMI unless someone can tell me a reason not too.
    Im wanting the best pic possible, watch tv mainly, but would like to watch dvd's and play on my xbox, also it will be wall mounted so no need for table top stands or speakers.
    Many thanks for all your help.:)
  2. HoTTdog
    HoTTdog
    Feb 7, 2006
    190
    Kent
  3. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    LOL wise words, Hottdog! If you are using an external sound system, you can include panel only plasmas in your search. It's a broad consensus that the best of this type currently is the PHD8 panasonic. HDMI, well my advice is it does not make much difference whether a connection is analogue or digital, as long as it's a good one. But then, don't spend a fortune, cos you'll be wanting a HD player of some sort when they are available, it would be a shame to spend too much for short term gain.
