2k Dome cameras, NVR and PoE help.
Discussion in 'Smart Home, Climate Control & Security Forum' started by armourdillo, Mar 11, 2018.
  1. armourdillo
    armourdillo
    Feb 5, 2006
    569
    Coventry
    +37
    Hi everyone,
    I would like to setup some CCTV.
    Looking to put two outdoor domes up.
    I would like some help in what to select.
    Also the NVR would be in the loft or maybe downstairs.
    Any recommendation on equipment and could I use power line adapters to help cabling.
    Can I use PoE with power line adapters?
    The NVR must be able to email motion triggered photos on a motion alarm.
    Any help would be great and if you need more information from me please ask.
    Thanks again.
  2. mushii
    mushii
    Apr 3, 2003
    2,193
    116
    Stoke On Trent
    +1,171
    Hikvision
  3. Markr123
    Markr123
    Oct 24, 2015
    28
    Uk
    +45
    Sorry, no you cannot. If there is is power close by, use that. PoE is only available using run from the PoE injector / Switch to the endpoint device.
  4. armourdillo
    armourdillo
    Feb 5, 2006
    569
    Coventry
    +37
    Ah, I see.
    Can I use the powerline adaptor to run from the home hub up into the loft, then connect that to a PoE switch?
    All the Poe stuff sits in the loft.
  5. Markr123
    Markr123
    Oct 24, 2015
    28
    Uk
    +45
    Hi, yes you can do that...
    Router > powerline ———- powerline > PoE Switch or injector > device
