2910 DVD-Audio menu via DVI
Discussion in 'Blu-ray & DVD Players & Recorders' started by BlackCatz, Jan 21, 2005.
  1. BlackCatz
    BlackCatz
    Jan 17, 2005
    7
    Just bought my first DVD-Audio disc for my new Denon 2910. Great sound into my 2805, but I only seem to get the disc menu via the SCART, not via the DVI output. If I manually select the right group with the remote then playback of footage is fine via DVI, but still no menus? Any ideas?
    Thanks.
  2. Bruce1310
    Bruce1310
    Dec 7, 2004
    227
    19
    Aylesbury, Bucks
    Hi BlackCatz,
    I'm not sure if it's the same with the 2910 but there is a problem with the 3910 and firware release ****-5....for some reason there is a problem viewing the menu on DVD-A throught the DVI...this seems to be disabled for some reason. Apparently a new firmware (available in the USA and other regions) will fix that. If you do a search you should find more info. Hope that is of some help.
    Bruce
  3. BlackCatz
    BlackCatz
    Jan 17, 2005
    7
    Thanks... will have more of a search.
