2910/3910 with AE700
Discussion in 'Projectors, Screens & Video Processors' started by 1ofaKind, Oct 9, 2004.
  1. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Hi All,
    I am currently looking at plasma/projectors (not decided which way yet but swaying towards projector at the present time).
    I would be looking at 3 cable runs to the PJ. A component set of cables from Denon 3805 which will deal with everything except DVD. Then a HDMI cable from the DVD to the PJ and finally a VGA cable from a PC (normal not dedicated HTPC).
    Are there any known problems (i've already read about DVI problems with upscaling on Panny plasmas) which using the upscaling features of the DVD over HDMI (720p and 1080i) into this projector. Of course the material will be NTSC and PAL off the multi-region player. Has anyone uses this configuration of DVD/PJ yet and tested both PAL & NTSC upscaling?
    Ideally I'd like to start off using the conversion to component of the amp for the rest of my stuff (VCR,Xbox etc) and then maybe add a scaler later when I have more free cash :)
    Any comments?
  2. JonMace
    JonMace
    Nov 20, 2002
    2,536
    83
    Kent
    +207
    I have the panny 700 and have just brought the Denon 2910 to go with it, great DVD player, I'm waiting for the HDMI cable so will post results when I get it
  3. rob j
    rob j
    Aug 10, 2002
    550
    +21
    Hi Jon :)
    Can I ask where you got your Denon 2910 from? I want one now but the places I looked at did not have them in stock yet!
    Your help would be greatly appreciated! :smashin:
    Thanks!
  4. JonMace
    JonMace
    Nov 20, 2002
    2,536
    83
    Kent
    +207
    Musical Images in Beckenham
  5. rob j
    rob j
    Aug 10, 2002
    550
    +21
    Thanks!
  6. 1ofaKind
    1ofaKind
    Dec 16, 2002
    233
    Midlands
    +4
    Any reports/feedback yet?
  7. JonMace
    JonMace
    Nov 20, 2002
    2,536
    83
    Kent
    +207
    Got my HDMI cable and am having problems, the pictur looks great but every 1/2 hour or so I get snow then it looses the signal then it reappears very annoying
