29" Panasonic Just Died - Help?
Discussion in 'General TV Discussions Forum' started by gbmitie, Jun 28, 2003.
Tags:
  1. gbmitie
    gbmitie
    Apr 25, 2001
    1,141
    49
    republic of ireland now
    +62
    I usually leave my tv on most of the day(work from home) and switch to standby for some periods. Yesterday was a bad hair day and went to TV that was already on stnadby but pressed on/off switch on front by mistake, then realsising I had switched it off I pressed again to bring back on and it went dead! Checked fuse, ok, different outlet, oK.
    Before I call repair man is there another fuse within the set or a reset function that I can try or anything else that may revive it. It is 7 years old but was in tip top condition, picture fab as it had a phillips crt.
    Thanks.
    gb--
