28pw6305 problems
Discussion in 'General TV Discussions Forum' started by wallclock, Aug 22, 2001.
  1. wallclock
    wallclock
    am i expecting to much. audio dropingout most predictable during intro to titanic played back on two diffrent dvd players otherwise happens only on music in films. one av input bleeding through to another with itv digital pluged int ext1 and dvd pluged into ext2 the itvd picture can be seen rolling in the background (dvd on screen saver), tv volume turned up itvd box can be heard.
  2. mv
    mv
    Do you have problems with the scart plugs??Ghosting problem!!
    Is that a borrowed copy of Titanic??
    Should of bought the Toshiba!!
  3. Guest
    Looks to me that the TV is faulty, I have the same TV as you yet experience no such problems, my DVD is EXT 1 and Sky EXT2 but i never get any ghosting or interference from either source, apart from saying you should have got a Tosh, problems can appear on ANY make or model of TV, the 6305 is no exception. The only gripe i have with it is the lack of autoswitching, having to to it manually becomes a chore, but i can live with that.
    <br />Forgot. You say DVD is in EXT 2 so you will be using composite or SVIDEO correct? Try swapping the Scarts around and see if this cures it. It seems that the Svideo is getting preference to the RGB signal.
    andyw
    [ 22-08-2001: Message edited by: andyw ]</p>
  4. wallclock
    wallclock
    andyw are you also not expieriencing the audio fault. This is the second unit i've had. with itvd switched off there is no double image. with dvd set to ntsc there is no double image. swoping inputs the same problem exists on ext 2. with my dvd powered down (connected ext 2). i can hear <br />ext 1 audio bleeding through. i have used another dvd on ext2 same prob. v.frustrated. AV inputs are supposed to be isolated until there switched.
  5. Guest
    No Steve I am not having audio problems, could be because i have Sky and not ITV digital although i will try and replicate your problem, I could have missed something or my configuration wouldn't show it up, I'll get back to you about it m8
    <br />andyw
  6. Guest
    Are you using individually shielded scart cables? If not try them, and/or disconnect pin 20 on your DVD scart lead (ground), this can also eliviate the problem with ghosting.
    <br />So, go for high quality scart cables<br />If this fails, try disconnecting pin 20 in your scart
    I've still got to try and replicate your faults Steve
    <br />andyw
  7. wallclock
    wallclock
    been a while since i replied to the last message was posted. have been busy had the tv changed same problems exist must be down to design. by padding the output of either my dvd or itv digital by about 10-15 db the audio probs disappear? had engineer visit to see problem don't think he could of cared less. can't believe no one else has experienced this. or has lightning struck twice?
  8. Guest
    hi Steve, you do seem to be unlucky don't you <img src="frown.gif" border="0"> <br />I have tried to replicate your faults but couldn't. Titanic played faultlessly all the way through. It does seem very unlikely that you would suffer from the same problem twice over, but i would say that you either a) Had 2 early versions of this TV which had problems or b) Your setup just doesn't like the Philips. Did you try the pin 20 test, apart from this it looks like another make of TV for you, sorry I couldn't help more
    andyw
  9. MikeyB
    MikeyB
    Sep 24, 2001
    80
    Swindon
    I get the ghosting problems wallclock talks about.
    If im watching DVD (ext1) or Sky (ext2) I can see the "outlines" of another picture moving across the screen in the background. This is more noticeable on areas of the same colour, and it turns out to be the picture on whatever analogue terrestrial channel the tv was in before switching to ext1 or 2, unplugging the areal lead gets rid of it.
    I will try the PIN 20 trick when I get time, might have to wait till I get back from holiday.
  10. MikeyB
    MikeyB
    Sep 24, 2001
    80
    Swindon
    Just to let you know, I've tried disconnecting pin20 like andyw said, but it made no difference to the picture. I'm gonna get hold of some better quality scart leads and see how that helps, thanx for the ideas anyway!
