28LD5200 and dvi connection
Discussion in 'LCD & LED LCD TVs Forum' started by Hass, Dec 21, 2004.
Tags:
  1. Hass
    Hass
    Dec 21, 2004
    16
    Has anyone had any luck connecting their 28LD5200 up to their pc using the dvi input? For some reason, I can only get the tele to sync to the signal if I disable my graphics card and default to the standard windows drivers?
    Apparently this problem doesn't manifest itself with the analouge input but I'm loathed to follow this option because my graphics card doesn't have an analogue out.
    I've gone through all the resolutions the manual says are supported on the dvi in but no luck. Anyone been succesful in attempting this?
  2. flangemonkey
    flangemonkey
    Nov 27, 2003
    359
    28
    +48
    I had no problems here with my 28LD5200 and my Radeon 8500DV with the ATI catalysts...got it working with both DVI and the analogue D-Sub. My card only has a DVI output, but I also have a DVI->15-pin dongle that converts the signal...
    You really need to set the res of your card to 1280x720, as this is the native res of the display...it also worked with 1024x768 IIRC and a few others...
    I also fiddled with Powerstrip to get some custom resolutions/refresh rates to try out, had some 720p material playing on the Hitachi in native res. and it was wonderful...
