2802 price search
Discussion in 'AV Receivers & Amplifiers' started by nickane, Dec 12, 2001.
  1. nickane
    nickane
    Nov 5, 2001
    124
    Ok, so the 3802 reigns supreme, but for those of us on some semblance of a budget, the 2802 with its mere 6.1-capability will have to suffice. But has anyone seen it for less than £500? I was going to get an Rxv-620RDS, but until Yamaha brings out a DPLII model the 2802 is my only option, as it has a good reputation and component switching.
    "Trying is the first step towards failure"
    Homer Simpson
  2. WSC
    WSC
    Nov 1, 2001
    60
    You can get it for ~485 from unbeatable and empiredirect.
    For ~350 you can also get the marantz 5200 which also has 6.1 and DPLII
    Need to listen to them to decide!
