2800mk2 unofficial website ??
Discussion in 'Blu-ray & DVD Players & Recorders' started by loftfuton, Mar 4, 2003.
  1. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Anyone know where I can find a good unofficial site for the 2800mk2. Done a few searches but only came up with 3800 site
    Ta
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
  3. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    I had a Denon 2800 and a 2800mk2 I had problems with both
    (not that you will) I had mine upgraded by my dealer.
    But even after the upgrade it was only multi-region but no PAL progressive, which is what I wanted. I've now upgraded to the 3800 and got my firmware upgrade from Jasonjo home page
    http://www.geocities.com/denon3800/ it's a great home page.
    I know this doesn't help you with what you want to know but if your looking for PAL progressive scan on your 2800mk2 I've been told by Denon UK that there is no firmware that works, only firmware for multi-region. The 3800 is not without it's problems as I found when I joined this forum a few days ago, but as the guys and girls will tell you if you have the latest built date player it should be fine.
    ASH1
  4. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Thanks to both for your info. I just had my 2800mk2 firmware upgraded by my dealer to output PAL prog. It has been doing that without any problems so far, and freezing I was getting with the earlier firmware has now gone.
    Will have a closer look at the 3800 site.
    All the best
    Harry
  5. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,649
    UK
    +112
    any chance you can get the firmware disc off of your dealer so others can use it?
    JJ
  6. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    Glad to here you have prog-scan with no problems, what are you useing for your monitor?
  7. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Viewing dvd with Sony VPL-VW10 projector.
    Firmware came from Creative Audio of Shrewsbury.
  8. MrC
    MrC
    So what firmware version is it?
  9. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Dont know - sorry. Sent machine back to be looked at as was having problems with the original pre-December firmware which converted pal to ntsc then progressive.
    They replaced this with the new firmware they received before Christmas, but I didn't ask for any details about it.
  10. MrC
    MrC
    check it yourself
    1) Press "PLAY" and "OPEN/CLOSE" while while pressing the power button on (on the machine, not the remote)
    2) Press "MENU" on remote
    3) Player display will show microprocessor version (DVR *-**)
    4) Press "MENU" again
    5) Player display will show software (ESS****) version
    6) Power off and then on before you use the machine again
  11. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Off now to sunny Spain for a week, but will do that when I get back and post answer - anyone want a stuffed donkey ??
  12. bob5
    bob5
    Dec 10, 2002
    17
    west sussex
    I've just ordered a 2800 mk2 from my local dealer on the understanding that it would do prog. scan on pal.
    checking a review it says it does ntsc prog scan only! quick call to dealer to cancel order resulted in him phoning denon importers and an up-grade disc will be with him on monday,supposedly.
    I await with bated breath!!
  13. MrC
    MrC
    Want to try and get the disk of him, copy the file and pass it around the users here?
  14. bob5
    bob5
    Dec 10, 2002
    17
    west sussex
    I'll let you know on monday or tuesday.
  15. ASH1
    ASH1
    Mar 1, 2003
    1,208
    +61
    bob5,
    If you can afford it spend the extra and get a 3800, you may have read I had a 2800mk2 (not that you will have trouble with yours) But I've seen a difference in performance in Picture and music,
    for the better that is.:)
    ASH1
  16. loftfuton
    loftfuton
    Feb 4, 2003
    93
    BELFAST
    Back from holidays. Dont know if this is still relevant, but checked my firmware version;
    Microprocessor DVR 1-69-0
    Software ESS 91 04-3
    Harry
