28" Widescreen TV - Which one?
Discussion in 'General TV Discussions Forum' started by unbreakable, Jul 9, 2003.
  1. unbreakable
    unbreakable
    Jul 9, 2003
    17
    Norwood Green, London
    Hello people.
    I am new to this site, infact I am glad I found it, maybe you guys might be able to help me.
    I am looking to buy a Widescreen TV for the first time.
    Due to the small room I have, 28" is perfect.
    I have looked at Panasonic, Philips and Sony.
    I have a budget of £500. I know you can pick them quite cheap from on-line retailers.
    I have been looking at the TX28PS12 which is the new model for the panasonic.
    Basically I wanted to know which is the BEST 28" TV to buy. The one with the least problems..etc.
    I have seen this Panasonic at John Lewis , it comes with 5 Years garauntee.
    I would appreciate your views guys.
    Thanks.
  2. zman
    zman
    Jul 2, 2003
    43
    uk
    +5
    I've got a jvc av28reks which i bought from comet for £600. I regret not buying it from unbeatable who ar doing it for £440. I think its an excellent tv IMO, mine came with the extra speakers which gives the tv dolby pro logic surround sound. The picture is great and it looks really cool too. Some experts might tell you about bad contrast but if you want a good tv then i'd recommend this one.
  3. njhpuk
    njhpuk
    I'd recommend the Toshiba 28W23B ... great picture & sound ... and I've seen it available at Tesco.com for only 299.99 !!! BARGAIN!!
