28" widescreen are them too small??
Discussion in 'General TV Discussions Forum' started by Squall Strife, Jun 25, 2003.
  1. Squall Strife
    Squall Strife
    Hi guys i'm gonna buy a new set and i need some advice 'bout it.
    I'm really interested in Panny TX28PL1 or Sony KV28LS35 but the question is: "Are 28" widescreen sets too small?". In particoular i need to know if the picture is fine with Playstation2 or Xbox (with DVD it should be fine) or if its too small. The room where i've to place the tv is not very big, kind of 3 metres from the tv to the place where i'm seat, so what do you think?
    Thanks ;)
  2. nathan_silly
    nathan_silly
    My previous TV was a 28" Panny widescreen, room size 3M x 4M. About right really- a 32" is too deep (takes up too much room, depth wise)
    Although saying that I'm now using a 42" RPTV, that in fact is slimmer than the 28"!!
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,523
    3
    Aldershot, Hampshire
    +286
    28" is ok but i'd go for a 32" if you could stretch to it.:cool:
    Size does matter when it comes to displays imo:D
    the bigger the better:devil:
  4. Radiohead
    Radiohead
    Dec 24, 2001
    4,380
    Amazingstoke
    +432
    Just went from a 28" to a 32" in a 16' x 11' room and the extra screen size makes a huge difference.
    Go for the 32" if you can. 3 metres to the TV should be fine for a 32".
  5. Bassbin
    Bassbin
    Mar 16, 2003
    2,541
    48
    Leicester
    +56
    28" is very small unless you are only a couple of metres from the set. As mentioned above they are also very deep for their size. 32" sets are better but for the price of a good one you can almost buy a 42" RPTV which, as Nathan mentioned, is about the same depth as a 20" CRTV set.
    I've currently got a 43"RPTV at home and a 29" 4:3 CDTV in my flat. I was going to buy a 28" WS set for the flat but the viewing distance is about 4m and when I measured out the screen it was tiny.
    I guess it all comes down to what the space you've got in your lounge and of course your budget.
  6. Squall Strife
    Squall Strife
    Thank you very much guys. Anyway the thing is that i've found the Panny 28PL1 at 600 € and the 32PL1 at 1000 € O_O, there are kind of 400 € of difference between the 28" set and the 32". So what i have I to do?
    In any case do you know any 32" 50hz widescreen tv not too expensive (my budget is 800-900 €) and first of all with a great picture?
    Thanks again.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Look at the 32" 50Hz Sonys then, both LS35 and DX40 under £1000
  8. Squall Strife
    Squall Strife
    Hi guys its me again :D i've found a Thomson 32" 50hz, it is the 32WF200G :
    http://www.thomson.it/images/TNE/pdfcontent/images/l_32wf200g.jpg
    The price is really good 590 € (its a special offer, this set normally costs 850€), i think i'll take it. Anyway what i would like to know is if Thomson sets have usually good picture and geometry, anyone knows?
