Quantcast
28" TV with component connections ?
M
macmonkey
I'm looking for a 28" TV with component connections. Had my eye on the Toshiba 28ZD26 but can't seem to find one anywhere. Does anyone have any suggestions on which brand/model would be a suitable equivalent?
Thanks in anticipation . . .
M
MN8
Hi Macmonkey,
I could only find them at Electrical Discount UK and at Buyyourav
did a search for the model number on Dealtime.co.uk
http://www.dealtime.co.uk/xFS?FN=&KW=28zd26&FD=0
I bought the last one at Electrical Discount and the model isnt made anymore so I guess you should try the Buyyourav site at £539 - website says they have stock.
You may want to read my earlier thread 28" Best Buy as I got some useful advice before choosing mine and am really happy with it.
Good Luck M8
T
Totalnoobee
Another alternative is JVC's 28P37, it has component inputs and its PAL/NTSC progressive + HDTV compatible.
