Quantcast
28 or 32
J
jackal_jd
I'm getting Sky+ in 10 days and I am yet to get a widescreen telly for it!! I will probably get the Sony KV 32 or 28 FX66. On 'normal' sky digital, my signal strength is about 80%. I sit about 2-3m away from the TV. If I got a 32", on Sky+ would I see dots, lines and graines?
Jon
Garrett
Go for the 32 I sit within those distances and I see no problems, you will see the Red Dot though.;)
My signal strength is about 75% on a normal box.
C
CarlosTheJackel
I think he means the "interactive" dot:D Its got to be a 32"
J
jackal_jd
Seriously though, did you mean the sky interactive button or is there a fault on the fx66?
Garrett
The red dot was a joke hence the smile, I meant the interactive dot.
Sorry to confuse you.:blush:
C
CarlosTheJackel
Damn, there was me with the pledge trying to remove it from the screen!;)
