28" or 32"
Discussion in 'General TV Discussions Forum' started by Manny Brown, Jan 2, 2004.
  1. Manny Brown
    Manny Brown
    AVF Games Reviewer
    Dec 30, 2003
    716
    46
    Cheltenham
    +157
    ok, my choice has settled on the Philips P+ model now (i know, i know....)
    however, my new dilemma is over 28" or 32". I currently have a 28" screen and this seems fine, I sit approximately 6-7 feet away from the screen.
    What do you think? will 32" be too big for the viewing distance? or would I benefit from the extra size?
    any info or opinions would be useful.
    cheers,
    Manny
  2. PaulJ
    PaulJ
    I sit about the same distance as you and have no problems with my 32".
    If I'd have had the room, i'd probably have got a 36" and would have watched from the same distance.
    The bigger the better ! :D
  3. deckard
    deckard
    Dec 4, 2002
    425
    16
    leicester
    32", no question.
  4. Kahless725
    Kahless725
    32 Inch quality set no question but from personal experiance I would get a 100hz if you are so close to it as the closer you get to a tv the more apparent (to me) that the flickering is.
    Also quality because you are so close to it. The further away from it you are the more forgiving a less decent picture is.
    If you cannot afford a 32 inch quality set then I would go for 28 inch.
