27WL46 v 30WL46
S
seanh79
Can anyone give me an opinion on whether the extra 3" makes much of a diference? It's for a fairly small flat which makes the smaller screen attractive but the 30" isn't much more expensive - anyone have any thoughts?
A
AgentPingu
One thing I can tell you is that the 27" is classed as a 'medium' size screen, where as the 30" is classed as large.
I do feel it makes quite a difference, I tried putting a cardboard cut out on my wall and compared the two sizes, 30" seems to give that cinema feel moreso than the 27".
I'm holding out to get a 30", but then viewing distance does come into it. Mines about 2.5/3m, the general consensous seems to be that I need 30"-32" but no bigger/smaller.
If yours is less then a 27" should suffice, just depends whether u want a screen to 'suffice' or a screen to seems massssssssive. :eek:)
S
seanh79
viewing distance would range from 2.5metres for movies to about 1 for the playstation
A
AgentPingu
:) lol, sitting close is the cheapest way to make any screen seem big :thumbsup:
I certainly don't think a 27" would be too small, a friend of mine has a 22" Samsung from a similiar viewing distance, and it does the job.
I reckon Jimsan will be the man to advise u on this one, but beware, he'll try to make you buy a Philips 32PF9986, I've a feeling he gives his a kiss goodnight each evening. But then they are quite sexy. :smashin:
A
AgentPingu
and at the end of the day, it's one of those things that comes down to personal opinion.
