micks_address
Hi folks,
In relation to the Video DA Converter - is a 54mhz noticeabley better than a 27 Mhz output. Also if I have a 54mhz output should i be using a higher quality of scart cable. I currently use a gold plated fully wired cable but should i use an rgb only one?. Would the quality be better?.
I have a Sony NS900. I upgraded from an NS700. I'm happy with the player but I had to get the fix applied to sort out the av switching problem. The rgb is a little darker than svideo but i'm wondering is this due to the 54mhz output and the fact that the scart cable can carry a higer colour bandwidth?.
Thanks,
Mick
Thanks,
Mick
