26inch lcd for 489.99
Discussion in 'LCD & LED LCD TVs' started by Akcron, Aug 16, 2005.
  1. Akcron
    Akcron
    Sep 8, 2004
    164
    +4
    Hi ive just seen this on currys mail order site ,
    NEOVIA NEO-2601ES..for 489.99
    currys site says 12 ms refresh the following stats are from the neovia site
    PANEL Aspect Ratio 16/9
    Screen Size (cm/inch) 67cm/26
    Resolution (pixels) h x v WXGA 1280x768
    Contrast Ratio 500:1
    Brightness (cd/m2)) 450cd/m²
    Viewing Angle (Hor:/Vert.) > 176/176
    IMAGE Image Format (Normal, Zoom, 16/9, 4/3, Automatic) 6
    Image Mode (Dynamic/Standard/Soft/Games/User) 4
    Progressive Scan yes
    AUDIO Stereo (A2, NICAM) yes
    Equalizer yes
    Power out (RMS) 2 x 3W
    Musical Power 2 x 6W
    Sound Mode (Flat, Music, Cinema, Speech, User) 5
    OTHER FEATURES Sleep Timer yes
    Teletext 250 Pages
    Multi-langue OSD yes
    Remote Control yes
    Wall Mount Compatible (WESA for LCD) built-in
    PIP Function (Picture in Picture) on PC/YPbPr
    COMBO Hard Disk Drive Integrated (Time Shift) -
    DVD Player Integrated (DVD-R/-RW/+R/+RW
    Super VCD/VCD/CD/CD-R/RW/JPEG/MP3) -
    Wireless Headset (Option) -
    CONNECTORS Connection PC/D-Sub 1
    Entry Audio PC 1
    Connection DVI (Digital Virtual Interface) -
    Connector SCART 1
    Entry S-Video 1
    Entry Antenna 1
    Entry Audio 1
    Exit A/V (RCA) -
    Exit PC Audio 1
    Exit for Headphones 1
    TUNER MultiEuropean Tuner PAL/SECAM-BG, I, DK,
    SECAM-L/L, NTSC-4, 43 yes
    Number of Channels 100
    Programation Manual or Automatic yes
    CONSUMPTION Maximal Consumption <140W
    Power 110-240V
    DIMENSION Dimension Without Stand (WxHxD) mm 690x135x522
    Dimension With Stand (WxHxD) mm 690x300x538
    Weight in Kg. 22
    has anyone tried one of these ???? and what do u think..
