26" with Digital Inputs?
Discussion in 'LCD & LED LCD TVs Forum' started by Bluestraw, Jul 20, 2005.
Tags:
  1. Bluestraw
    Bluestraw
    Apr 9, 2005
    286
    +14
    Does anybody have a list of the 26" panels which accept digital inputs (DVI and / or HDMI)? It seems these are a bit rare?!
    Help much appreciated ! :lease:
  2. Loada
    Loada
    Mar 4, 2003
    592
    Guisborough, North Yorkshire
    +51
    There's the Sharp GA3E on Richer Sounds atm for £799...comes with DVI.
  3. Doctor Hades
    Doctor Hades
    Jul 10, 2005
    3,428
    East Yorkshire
    +313
    Well I'm considering three at the moment that all have HDMI and/or D-SUB. None have DVI though as far as know since HDMI is backward compatible with it I believe. The three panels are:
    Samsung LE-26R41BDX or the later model LE-26R51BDX
    JVC LT-26DS6BJ
    Panasonic TX26LXD500
    Bar the Samsung models, which cost around £700, the others are expensive at over £1,000. I'm waiting for the JVC panel to go down a bit in price before I order it.
  4. benwong
    benwong
    There are a couple of budget 26" screens doing the rounds with DVI inputs, but these are not HD ready as far as I know.
    They can be had for around the £500 mark from either Sainsburys or Asda (the Dual branded one from Asda seems to be favoured over the 2 as it is slightly newer, with slightly fewer issues).
    If you only require a digital input (without the need for HD tv compatibility) then you might wanna have a look.
    Just do a search for Sonix or Dual.
    I think there's also a 26" Toshiba being sold on Pixmania around £500-£600 with a DVI (non HD TV compliant) input.
    Just remember though; you get what you pay for..
    Ben
