26" or 28" LCD
Discussion in 'What Is The Best TV For You?' started by Riddler91, Jun 2, 2008.
  1. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Hi, im pretty new to all this stuff :confused: and i was wondering whether there is any differenence between a 26" LCD screen and a 28" LCD screen, and i dont mean 2", im talking quality and resolution.
    This is because i have just baught a PS3 and i am looking for a new TV for my room.
    Can anyone help and possibly give any suggestions for an LCD TV of this size?:lease:
    Thank You!:)
  2. YellowSphere
    YellowSphere
    Dec 2, 2007
    4,448
    103
    +471
    There aren't any 28" sets, and if they are, they'll be small brands that are most likely not worth bothering with.
    26" it is then. Sony T3000 and S3000 are good. Philips and Toshiba are also worth looking at.
  3. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    The 26T3000 is the best definitely the 26S3000 has lower panel(TN)
  4. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Oh ok, i had just seen 28" on samsung website.
    They are quite expensive from sony, do you know anywhere or a website that does them cheaper?
    Thanks btw
  5. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    ehh?there is no 28" lcd
  6. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    :confused: my bad, guess i miss read it! sorry
  7. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    iirc...not got a tape to measure but a 26" LCD gives you the same screen size/area of a 28" CRT...waits for someone to do the math and tell me I'm wrong ;)
    Curly
  8. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Sorry, but what do you mean by a "lower panel(TN)" ?
    Because $400 is a little over my price range, but the S3000 is closer to what i want to spend, unless there is a significant enough difference!
  9. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    TN,not S-PVA panel.TN is a cheap panel with no good viewing angles.The 26T3000 can be had for £400 I think
  10. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Ok, so the T3000 is definately worth the extra cash?
  11. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Yes :)
  12. ChrisGgr
    ChrisGgr
    Jun 10, 2007
    14,742
    Greece
    +1,499
    yep
  13. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Thankyou for your advice. I'm definately going to go for that then :thumbsup:.
    While im here though, my brother has asked me to help him find a smaller screen. He is hoping for a 22" and nothing very expensive at all, im not sure exactly what price range he is looking at but i think it will be around £200-£250 I guess, like I said, nothing overly expensive. He is hoping it has HD ready and has HDMI connections because he is hoping to get a PS3 after his birthday in July. You couldnt help me out again could you :lease: because I cant make a decision without anyone elses views and reviews.
    Might be a bit of a challenge but i have faith in you all :smashin:
    Thanks again!
  14. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  15. Riddler91
    Riddler91
    Jun 1, 2008
    112
    16
    Wow nice find :thumbsup: Thanks :smashin:
  16. golly99
    golly99
    Mar 5, 2006
    493
    28
    +34
    Seems to be a bit of slant towards Sony on these forums, personally I would consider the Panasonic LXD70 - that is the best 26" and most feature specced tv on the market - bit more expensive than then Sony but if you compare the two there is no comparison!
  17. akhlaq768
    akhlaq768
    Oct 14, 2006
    813
    +5
    is there one for around the £300 mark?
  18. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
  19. akhlaq768
    akhlaq768
    Oct 14, 2006
    813
    +5
    cheers bud, will take a look
  20. akhlaq768
    akhlaq768
    Oct 14, 2006
    813
    +5
    looking at it... the philips 32" is cheaper than the 26" by £30
    what is the difference between both apart from the inches?
